07/24/96-i430VX-W877-2A59GPA9C-00
zonxar
- Master Flasher
This appears to be an Epox P55-TV motherboard, 4 ISA, 4 PCI, 4 SIMM, 1 DIMM, Intel 430VX chipset, AT. Support page here:
http://www-old.epox.nl/english/support/ ... t.php?id=6
Download an older DOS version and run it from a boot diskette.
The following is full text of the bios.txt file that I got when I ran BIOS Agent.
BIOS Date: 07/24/96
BIOS ID: 07/24/96-i430VX-W877-2A59GPA9C-00
OEM Sign-On: 07/24/1996 For i430VX PCIset
Chipset: Intel Triton 430VX rev 2
Superio: C&T 82C735 or SMC 661/663/664 rev 0 found at port 3F0h
Superio: Winbond 877F (use 87h) rev 0 found at port 3F0h
CPU Type: Pentium
CPU Speed: 166 Mhz
CPU Max: 100 Mhz
BIOS ROM In Socket: No
BIOS ROM Size: 128K
Memory Installed: Unknown
Memory Maximum: Unknown
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
SMT P55VX
Winco W-P55TV
EPoX EP-P55-TV
EPoX EP-P55-VX
And other manufacturers has this motherboard with different names
Winco W-P55TV
EPoX EP-P55-TV
EPoX EP-P55-VX
zonxar
- Master Flasher
I neglected to mention that the P55-TV also has a cache slot next to the CPU. Yes, the boards are different - the P55-VX doesn't have the cache slot or DIMM, 3 ISA, 4 PCI, 4 SIMMs and is an AT board. Here are some images of each:
P55-VX
P55-TV
P55-VX
P55-TV
No.Chris1992 wrote:are all the boards same physically?
I have the P55TV then. Wondering what that slot next to CPU was. How does this board work under Linux? (as I was planning to install Mandriva LE2005)
zonxar
- Master Flasher
Here is a page with some settings as well, it appears the max memory is only 128 MB of EDO:
http://th99.dyndns.org/m/E-H/33833.htm
Were you able to reach the Epox link I included earlier? It had manual, driver and BIOS info.
