boot block
If the board has integrated VGA then the code will need to be in the bootblock.
If you have a plug-in VGA card then the code is on the card; but the boot block needs to be able to set up the chipset to find the card. Some boot blocks could only find an ISA card. If the board did not have an ISA slot this was a problem.
