I want to upgrade my emachine T4150 Motherboard's bios to the latest one
this is the bios info
BIOS Date: 09/12/01
BIOS ID: 09/12/2001-i845-LPC47M19-6A69VF0AC
OEM Sign-On: Version IED42
Chipset: Intel 1A30 rev 3
Superio: Unknown
OS: WinXP SP2
CPU: Intel Pentium(R) 4 1700 Mhz MAX: 2400 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 2048 MB
Memory Slot 01: 256 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
I went to the site
http://www.fic.com.tw/product/motherboard
and found my motherboard, BIOS FIC VC31
Current System Bios says IED42, and in the site the name IEA45 is the latest one
However, I think in my current bios the name is wrong, Its IED42, but its supposed to be IEA42,
I tried to update the bios but it says
The program file's BIOS-Lock String does not match with your system!
so what can ido?
Help Me Out
eMachines...
The latest version I know is IED41, so yours is newest.
but how can mine be newest when my version is IED42??KURIAKI wrote:eMachines...
The latest one is IEA45 and i installed it already, and i am up and running
However, the emachines recovery CD does not work anymore, i mean i load windows, but windows will not work from the recovery CD
i have to use the Windows XP CD from Microsoft itself
So what can i do to fix that?
IED Bios is a special OEM Bios for eMachines, IEA Bios is the retail Bios. It may be for the same motherboard revision or not, sometimes it works installing a retail Bios instead of the OEM Bios but not always.
To get the Recovery Cd working you need to reinstall the OEM Bios. But as you have a verifyable XP license you should be able to install XP from a standard XP install disk, even a copied one, but you need to use your serial number as seen on your M$ certificate.
