been busy. need help on what brand/model these two mboards are. Need links for its bios/driver and manual.
1.) Super Socket 7 / 2 SDRAm slots / 4 PCI slots / ATX
VIA VT8501 Northbridge and VIA VT82C646A Southbridge
> It has a print: PWA-PWA-CAMARO-1.5C MOTHERBOARD
PCB-TWA-CAMARO-1.5C MOTHERBOARD R0
2.) S370 / 2 SDRAM slots / 3 PCI slots / Intel 810 chipset / ITE Super I/O
> It has a print: Mat, NO: 120803 ANAHEIM3 REV. F
Pls help me
Help me again
Motherboard saved!
1.)
MiTAC 5114VU (used in Compaq Presario 7400)
Manual: http://www.motherboards.org/files/manuals/78/5114VU.pdf
BIOS: (IF COMPAQ)
http://h10025.www1.hp.com/ewfrf/wc/soft ... g=en&os=20#
BIOS: (IF NOT COMPAQ)
http://kuriaki.myftp.org:8245/Archives/ ... AC/5114VU/
2.)
TriGem Anaheim-3 (used in eMachines eTower 667ir, 700, 700id, 700ir, 700irx,766, 766id eMonster 800, T1855, T1905)
BIOS:
http://www.elhvb.com/mboards/TriGem/bio ... index.html
BIOS: (IF COMPAQ)
2.)
BIOS:
thnx cp. will post result as soon as i can
Motherboard saved!
Andronicus
I believe I have that same Motherboard. Currently it will not support 48Bit LBA (over 137GB) Harddrive. Do any of those BIOSs you have linked to correct this?
One _could_ rewrite the whole IDE detection section to support LBA48, but i doubt anyone will ever. If you are using a modern operating system like Windows XP or 2000 SP4+ or even Linux you don't need to bother about the BIOS anyways. They all use their own routines to bypass (bogus) BIOS.
Andronicus
Cool. I found a program from intel that allows new OSs to read the large harddrives.
edit: URLs don't seem to work as shown, Oh well, there it is anyway.
edit by Edwin: if you make Code out of it it will show the whole thing. phpBB cannot handle the * and % very well for some reason.
Code: Select all
http://downloadfinder.intel.com/scripts-df-external/Detail_Desc.aspx?agr=N&ProductID=663&DwnldID=4857&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=engedit: URLs don't seem to work as shown, Oh well, there it is anyway.
Windows XP / Windows 2k SP4 and Linux support LBA48 right out of the box for (almost, except one ALi SB) any chipset. no need for a special driver.
btw. there are drivers from almost any chipset manufacturer (i know of VIA and SIS) that support LBA48 for the old Windows distributions.
remind me of writing a sticky note so that i don't have to post it all over again ;)
