I'm looking for a manual for the motherboard " Tyan S1833D "
BIOS String:
62-0314-009999-00101111-071595-440BX
By the way, it's a DUAL Pentium II/III motherboard and it's not present at the tyan.com website.
Does someone have a manual for this motherboard, or does someone know where I can get it ??
Looking for a manual " Tyan S1833D "
I believe it's an oemed board for Gateway systems, specifically the E-5200. Please verify this.
http://support.gateway.com/support/manl ... 5200.shtml
Hi, I have the same motherboard which is made by Tyan as an OEM board for Gateway. The board is also known as the Patriot. Try this URL for some settings:
http://support.gateway.com/s/MOTHERBD/t ... 05nv.shtml
I haven't been able to find a real manual, but this should at least get you started. FYI, I believe the closest Tyan board is called the Tiger S1832DL. The specs look to be the same.
Good Luck!
Good Luck!
