does anybody know of a place to download a manual for the Gateway 4000206? TIA.
Best
Rolf
Manual for a Gateway board
Did you try the "email Gateway" link ?
OEM version of the Intel AL440LX board.
http://www.intel.com/support/motherboar ... p/al440lx/
these are the maunal/manual update... Adobe Acrobat Reader is needed to view. Please note the drivers from that page should work, but the BIOS will have to come from Gateway...Technical Product Specification [67702801.PDF]
Motherboard Specification Update [68688616.PDF]
Compaq-Fu Master
