I need an update for this bios :
Award Modular BIOS v4.51PG
12/24/1999-i440BX-ITE867-2A69KS2IC-00
6BA+ III-2BA1
Intel 440BX/ZX rev 3
please help me
tx
Bios udate for i440BX-ITE867-2A69KS2IC-00
Hello, and thanks for the link to the bios update.
Unfortunatelly I got another problem.
I flashed my bios with an old one that I found. The pc , started with the new bios , but I always had the problem with the memory recogniction.(It went worst. Onlt 64gb of 124 where recognized).
So I flahed the bios to the other one , but when I started the pc I got
1 long beep followed by 2 short beeps , and the screen was black . I searched for the soluytion and I found that it could be a memory problem or video card problem. I tried to remove the video card and reinstalling it or remove the memory cards and reinstalling it , but I keep getting black screen and 1 long beep followed by 2 short beeps .
Is there any way to know if I destroied my memory cards or video cards??
Do u suggest something ??
thank u for your time
From the manual:
CMOS Clearing (JP5)
After you have turned off your computer, clear the CMOS memory by momentarily shorting pins 2-3 on jumper JP5, for a few seconds.
Then restore JP5 to the initial 1-2 jumper setting in order to recover and retain the default settings.
Jumper JP5 can be easily identified by its white colored cap.
CMOS Clearing (JP5)
my motherboard manual is this:
http://motherboards.org/files/manuals/94/61bxam.pdf
I can NOT find any reference to the juper jp5.
Canu pls tell me how I could cleaning the CMOS please??
tx
tx
Just a moment... Are you talking about the same motherboard?
Soyo SY-6BA+ III or EPoX EP-61BXA-M?
64 or 128 not 124, I fear at least one of your memory cards is bad. Do you have other memory cards you can test?marcolisi wrote:...but I always had the problem with the memory recogniction.(It went worst. Onlt 64gb of 124 where recognized).
