I´m trying to flash my bios with the flashing utility from my bios provider, however no installation info about how to do this from xp is given. So no I have prepared a MS-DOS start up disk. But now the bios and flashing program doesn't fit on the disk. What can i do? can I leave the bios etc. on the hard drive and flash from there or can flash directly from the commad prompt in XP.
http://www.uniwill.com/UserDownload/N34B35B/N35B.htm
Uniwill flashing utility
Your DOS boot disk may be a bit crowded. Use the drdos flashing disk from here: http://www.bootdisk.com as it has the absolute minimum space used for a working bootdisk for bios flashing.
