Hi
I'm looking for a utility that will print the entire settings contents of the bios to a file, I don't even know if this is possible as I've not looked into it before. The Bios on my machine is award, OS is win2000
cheers
Pete
Bios utility
If you want to print how the current settings are, go into SETUP and use the printscreen key. You must have real printer (not a Windows-only crap) connected to LPT1 port.
ami's runsetup can capture the screen of cmos setup.
