I tried to update my bios, and now when I boot up my computer I get a screen that says
BIOS ROM Checksum Error
What do I do to get around this, I don't really know what I'm doing here.
I have an ASUS P4T533
Award Bootblock Checksum error
I tried downloading Uniflash and I still can't get it to work. Here is all of the information and messages I could find
Flash ROM Chip: SST 49LF004A/3.3v
Chipset: i850
I picked Flash BIOS Image from file to Flash TOM (without Boot Block)
The error message I get is Flash Data Verification Error
Please help, I really need this to be running again.
Chipset: i850
- Are those messages from Uniflash ?barry769 wrote:I tried downloading Uniflash and I still can't get it to work. Here is all of the information and messages I could find
Chipset: i850
- If so, I guess that means you can boot a diskette ?
- So can you use the flash utility supplied with the latest BIOS for the board ?
- Have you checked for a BIOS protection jumper ?
I can't find the flash utility directly from ASUS, I found something on their site called aflash, but when I run it I get some message about it not finding the bios' hook
Where do I find if I have this bios protection jumper
Precise error messages are always helpfulbarry769 wrote:I can't find the flash utility directly from ASUS, I found something on their site called aflash, but when I run it I get some message about it not finding the bios' hook
In the manual.Where do I find if I have this bios protection jumper
barry, i get the same boot hook error. your asus cd should have the awdflash bios flashing utility. this is the correct program to use for your flash.
i never got to run that awdflash program, as my comp will not post.
