Any support for this chip in Uniflash? Had a hosed flash on my Ti4800se card and want to revive it. Any sugestions appreciated.
Uniflash and Atmel 25f512n on ti4800se
Most likely, it will not work. However you don't need UniFlash. Insert a PCI graphics card, boot into DOS mode and reflash the card using utlity from its manufacturer.
