does anyone know if there exists a CMOS backup&restore utility ?
(I got an ASUS p4c800-e Deluxe motherboard)
CMOS bios settings backup utility
Are you talking about saving the CMOS settings or a utility to backup/restore the bin or ROM file itself?
Compaq-Fu Master
If you only want to save the 128 bytes:
http://www.filelibrary.com/Contents/DOS/54/18.html
has loads of them.
If you want to save the Extended CMOS as well, do a Google search for "Extended CMOS" save program
has loads of them.
Or try CMOS functions in UniFlash...
Is there no end to the capabilities of this program ?Rainbow wrote:Or try CMOS functions in UniFlash...
UniFlash can restore the CMOS settings that you saved as well??
There is Clear/Save/Restore. Should work with CMOS size of up to 256B. but it's not tested extensively.
