Hello,
I am trying to flash my bios using the award awdflash utility. I copied the bios upgrade V10091AG.BIN and the awdflash.exe file to a floppy and booted using a boot disc. I then swapped over to my floppy and typed awdflash.exe. I followed the prompts and saved my previous bios file and then entered V10091AG.BIN as the source file but I keep getting the error
"Source file could not be found"
Any ideas how to fix this?
Thanks..
Source file could not be found error.
www.bootdisk.com
-> Get the DRDOS 7.x "Basic-Biosflash" Bootdisk-creator and create a new bootdisk
Then you have maximum free memory to flash your Bios
Okay Denniss I gave that a try and it worked but when I tried to flash the BIOS I got an error message about checksum doesnt macth hardware or something. I continued anyway and the computer boots okay but I didnt manage to acheive the original goal of trying to update the BIOs to support a faster chip.
Anyway perhpas you could offer some advice on where to go from here? Here is the details of the computer.
An Azza DVBX2 motherboard with a Cleron 500mhz cpu.
Chipset is VIA VT82C693 and VIA VT82C596B
I am trying to upgrade the BIOs so I can install a faster chip as ther mobo manual says it supports up to 800mhz.
The current BIOS is this
Award Modular BIOS V4.51PG 1984-2000
1/13/2000 DVABX For PT-DVAX(2)/DVBX (2) 6VAX2
1/13/2000-693-596B-977-2A6LGP8EC-00
I went here
http://www.pcpartner.com.hk/support/bios/VIA694.HTM
And downloaded the bios that matched the chipset as above. However the computer will not boot with the new chip installed. I tried a few other chips but none of them will work except the original.
Any ideas on what I can try here?
Thanks again...
I went here
Thanks again...
Just to add I found a section in the mobo manual that says the Motherbaord supports a cpu voltage of 1.8v up to 3.5v and its automatically selected.
I also noticed that all the cpu's that I tried were all 1.7v.
Could this be the reason why I cant upgrade?
Why won't you install a Bios from your motherboard manufactuerer ?
A Bios from a different manufacturer but for the same chipset will not nork in 99% of all cases !
Your Bios should support these new CPU fine but you need a Slocket/Adaptercard with voltage select
-> With an 1.7V CPU and motherboard capable of delivering 1.8V as lowest it will not boot but if you manually select 1.8V it will boot .
Denniss,
I cannot find a BIOS from my motherboard manafacturer. Its an Azza motherboard and their websote only seems to support new boards. I have tried to Google for it but no luck so far.
Whe you say this
Any ideas?? Thanks again mate.
Whe you say this
Do you mean manually select 1.7v? If so thats a problem too. The board (As far as I can tell) automatically selects the voltage. You can change a jumper to increase the volatge by .5volts but thats the only control you have over it.-> With an 1.7V CPU and motherboard capable of delivering 1.8V as lowest it will not boot but if you manually select 1.8V it will boot .
A picture shows your board as Socket-370 - is this correct or do you have a Slot-1 Board ?
With Socket-370 it might be PPGA-only for old Celerons and for nothing newer .
Do not install a bios that's not designed for your board !!
The board has both a socket 370 and a slot 1 and you can use either processor in it. It is currently installed with a socket 370 500mhz celeron and I have been trying to upgrade this but with no luck.
Any ideas where I can find the right BIOS for this board?
Should I perhaps try to upgrade with a slot 1 processor instead? Will slot 1 processor have ahigher voltage of at least 1.8v or above??
Use your 1.7V Socket-370 CPU in a Slot1-to-Socket370 Adapter with voltage jumpers(required) and set these jumpers to 1.8V - no need to have a Voltage regulator on this Adapter
To repeat : This is not a Bios problem !!!
It's a hardware thing - if a CPU is detected requiring a lower voltage as the board is able to deliver there's no boot and board shuts itself down
Older Socket-370 boards do not support Coppermine CPUs even when the voltage regulator can do less than 1,8V. See this http://www.3feetunder.com/krick/370mod/
