Hello...
I’m working at a hospital and I need to change the settings of the BIOS for more than 200 new PCs, so is there a way to copy the bios settings of a good computer to the other PCs.
For example with a program that reads the settings in the setup from 1 computer and then copy or load them to all other PCs to automate the process... or by adding it to a bootdisk
instead of going into each PC an changing the settings.
Can you help me please with that, or any other ways to do so…
Please give me a hint...
Thank you
Help!! URGENT...Changing BIOS settings ?!! PLEASE
AFAIK Uniflash is able to save the current CMOS settings to a file and later write it back to a PC to test with .
Time might be affected as well resetting computer time to the time the CMOS was saved
But you must have the same Bios-version/-revision on all other PC
Use some PC to test this before trying to update all !
