Hi ,
i have a question:
i'm trying to mod the BIOS of an AsRock board.
The model is K7S41GX , bios version 2.80 , link to bios :
http://europe.asrock.com/downloadsite/b ... (2.80).zip
I'm able to succesfully replace/add modules using AMIBCP75. After modifying i checked the result file with an hex editor and all seems to be OK , modules checksums are OK.
There's only one thing i'm not sure it's ok, comparing the modded bios with the original one i can see in the hex editor that the first 4 bytes in the rom image are different. The original asrock bios has a 4 byte value that seems to be some sort of checksum , while in mod bios , generated with amibcp those bytes are set to 0xFF.
Can someone tell what's the exact meaning of those bytes ? Are thay some sort of checsum ? Are a vendor specific (ASROCK) checksum ?
I tryed all combinations for custom CRC and checksum algorithms but none of them produced the correct value .
I don't have a second board to recover bios if something goes wrong so i want to be 100% of what those bytes means .
Can they be a sort of checsum calculated at runtime then the bios is executed ?
Thanks .
Nico.
AsRock BIOS MOD
checksum is at the end of the file, not at the start. For sure AMIBCP being an AMI tool for AMI bios files, will not give you a corrupt bios.
Just always make sure you have a backup of your current bios and you know how to recover from a corrupt bios flash, just in case. This even applies to flashing manufacturer-made bioses.
first thanks for the reply.
I'm not sure if you downloaded and opened the bios file in an hex editor , but just in case you haven't , this is the start of the file :
0116DC6EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF.....
then there's an empty section (filled with 0xFF) and then the bios modules .
The file ends with 0xFC 0x00 .
All versions of the bios (i checked 2.80, 2.50 and 2.30) ends with the same word value (0xFC00) , so don't think this could either be a CRC or checksum , since the files should be identicals or have the same byte sum (i thinks it's impossible for 3 different files).
If you use AMIBCP75 and try to extract a module , then replace the same exact module without modifications and save the bios , what you obtain is an exact copy of the original bios , minus the first 4 bytes , that are overwritten with 0xFF , so , insted of 0x11 0x16 0xDC 0x6e (for bios rev 2.80) the files starts with 0xFF 0xFF 0xFF 0xFF.
The rest of the file , inclusding file size is the same . Just this 4 bytes difference .
I tryed to calculate the CRC and checksum of the file minus those 4 bytes but none of the algo i used produced a correct value.
And for the bios recovery , for Asrock motherboards it's simply not possible (at least not for my model K7S41GX ) since AMIBOOT.ROM method has been disabled by AsRock , so if you flash a wrong bios file the only chance to recover are by using a eeprom programmer (that i don't have ) , or try to reflashing by hot-swap (very risky ).
NIco.
NIco.
Hi again .
Last night i finally tried to flash the bios .
Is seems that the first 4 bytes in the image are simply not used . Maybe they are there for AsRock to identify a legit bios , but flashing with the bytes set to 0xFF didn't cause any problem.
Unfortunately now i have another problem , i was trying to change DMI data , but after modifying the DMI Data module , inserting into the bios , checking for the bios structure/checsums to be correct , i flashed the modded bios , but after reboot the DMI data structure hasm't changed.
I dumped the data with DMIScope and the old values were still there .
I think that asrock flash tool ASRFlash just didn't update all bios sections .
Can somebody tell me if there's a way to force all bios modules to be updated ?
I had some try with AMIFLASH but it says the chipset and flash rom type are not supported . Also ami flash for windows don't work .
What are you trying to achieve?
Oh and you are correct the normal bios tools do not work on Asrock bioses. They modified their version a bit. there's no recovery option.
