I m using MSI-K7N2GM-L Motherboard with Award Bios.
While modding the bios i happened to flash with a wrong version. Now the computer wont boot, the power gets on but no display and no sound.
I have also tried to recover from the bad flash by the bootable floppy but the computer does not boot from floppy. Now how should i make it boot from floppy so that the bios can be reflashed.
compuboy_r
Recovering From A Bad Flash
Time for www.badflash.com or similar offerings
compuboy_r
Is there anyway to check that is the boot block working, because i did not fiddle anything with the boot block.
compuboy_r
compuboy_r
If you did not use /wb switch when you flashed your BIOS, your BootBlock is still intact and recovery via bootblock is possible.
See related posts on "My Motherboard is Dead" forum about recovering from bootblock, or forcing bootblock to activate.
But if you're not comfortable with bootblock recovery, time for you to heed the advice of Denniss.
compuboy_r
Ah !!! Leave all.
I m not going to take any risks. Sent the motherboard back to dealer for replacement
compuboy_r
compuboy_r
