i have a 815e M/B,
It CAN ONLY RECOgNICE hd SMALLER THAN 128g.
SO I WANNA A TOOL TO break the limit,or someone can help me
break the limit.
THKS!
how to break 128g hd_limit?
Not possible to break. Bu Bios should detect 128Gb out of 160+ GB HDD and decent OS ike W2K/SP$, XP/SP1 , Linux and newer should be able to adress the space above 128GB. But you boot partition has to be inside the 128GB limit.
No chance with win9x unless you have a driver supporting 48 Bit LBA
xiaonian
- Master Flasher
but i do know some 815 m/b can support hd larger than 128g;
for example QDI sx2ep. here is its bios:
http://www.qdigrp.com/qdisite/eng/suppo ... chbios.htm
http://www.qdigrp.com/qdisite/driver/Te ... epv13a.BIN
