Hello everyone.
Laptop Manufacturer : HP
Laptop Version : HP G72-b10SW
Windows Version : Win7 x64
Bios version: F.48
Bios Driver : http://ftp.hp.com/pub/softpaq/sp55001-55500/sp55430.exe
I will start with a problem that i have met one day ago which made me try to reflash it in dos mode with UEFI.
I have got a modded driver from a site which i forgot his address but anyway the problem sounds like this :
I have entered in my bios menu and i have changed at Graphic Card from Hybrid to dGPU setting. Because there is some problems with Switchable Graphics claimed by all ATI users that have iGPU + dGPU. And after i saved the settings the laptop turned off and after few seconds turned on with CAPSLOCK + NUMLOCK LEDS Blinking two times + wait + two times again... continously. That means the bios is bricked or has some failures.
Now my problem is that i've tried to recover it with official files and original bios files with no luck.
I've made a USB Stick drive with HP UEFI driver, i've copied the result from decrypt process with phoenixtool which means from 01439.FD was 01439.FD.DEC + RSA.SIG
I have renamed to 01439.BIN + 01439.SIG and i have copied to the HP_TOOLS USB drive into X:\Hewlett-Packard\BIOS\Current
I have pushed the WIN+B key and power button after over 20-30 seconds the laptop stop blinking NUMLOCK+Capslock LEDS but it is giving me beeping sounds while i keep WIN+B key until i release them.
The problem is that the laptop is still in black screen mode. Which i want to tell you isn't from GPU's or anything else because it's a brand new motherboard bought one month ago.
I came here maybe if you can give me a way to succeed in recovering this dead notebook motherboard...
[HELP] BIOS bricked InsydeH2O F.48 (HP G72-b10SW laptop)
dodgy bios, replacement motherboard from an unknown source. how exactly are you expecting the official HP bios recovery procedure still working?because it's a brand new motherboard bought one month ago.
Start with tracking where you found the bios and state where you bought the replacement board. Then we may be able to tell what is wrong and how to handle things. It's very well possible the replacement board is not the official part number and needs a different bios than the HP original.
