i have a problem with my notebook just realized when using PC wizard 2008
here it is
i have "amilo m 1437g"
CPU information:
General Information :
Real Frequency : 800.03 MHz
Multiplier : 6x
Low/High Multiplier : 6x / 15x
Multiplier Locked : Yes
Marketing Frequency : 1995 MHz
taken from pc wizard
my cpu is locked to 800mhz. even if i run WoW, photoshop, MS Visual Studio bla bla bla... at the same time.its always 800 never changes. is that normal for notebooks?
i have great fps problem when playing world of warcraft and searching for a reason.
fsc amilo cpu speed
which cpu is build in?
did you check the PCWizard results with CPU-Z (http://www.cpuid.com/cpuz.php)?
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name Intel Pentium M 760
Codename Dothan
Specification Intel(R) Pentium(R) M processor 2.00GHz
Package Socket 479 mPGA (platform ID = 5h)
CPUID 6.D.8
Extended CPUID 6.D
Brand ID 22
Core Stepping C0
Technology 90 nm
Core Speed 800.0 MHz (6.0 x 133.3 MHz)
Rated Bus speed 533.4 MHz
Stock frequency 2000 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 15.0x
max VID 1.308 V
Features XD
on the PCWizard screenshot it says: CPU activity : 8%
the cpu is clocking down because there's nothing to crunch. you can get:
CPUBurn
http://pages.sbcglobal.net/redelm/
CPU Burn-In
http://users.bigpond.net.au/cpuburn/
to produce some load and run the programs again. i bet the values then read 2GHz :)
CPUBurn
CPU Burn-In
Were you running on batteries or on AC power when you took those readings?
True enough.cp wrote:AC power doesn't always mean that CPU frequency modulation is switched off.
On the other hand, many people aren't aware that their laptop will run differently when it is powered by a different source (and on their Power Options Control Panel settings naturally
Thanks.
