After flashing system BIOS of a desktop computer, the CMOS should usually be cleared. This often is done by removing the motherboard battery or using a jumpering Clear CMOS pins on the motherboard.
With a notebook computer, clearing the CMOS seems more difficult due to access difficulties to the motherboard battery (CMOS battery).
Should the CMOS be cleared after a BIOS flash of a notebook computer?
SOLVED: Clearing CMOS of Notebook Computer After BIOS Flash
before, reset to defaults (in bios setup), after, reset to defaults and save, then reboot, set things as you want. usually is good enough.
