Compaq Armada E500 bios dead
Bios update went bad even though update program said it was ok. Now just sits there with three lights on. Only thing that comes on is fan. Nothing else. Does this thing have boot block recovery pads ? If so, where on the board are they? If not, any other way to boot to floppy to reflash bios? I know some other laptops use a parallel port plug to activate the boot block. Thanks for the help
You already asked this at http://www.wimsbios.com/phpBB2/viewtopi ... highlight=
in "My motherboard is dead".
Please don't repeat yourself; read the posting rules. I don't know anything about Compaq.
