Hi all,
I delited a boot option in the bios unfortunately the motherboard option.... After that I only get a black screen isn and cd is working but can not get to the bios or boot menu.
Already tried
- boot nothing connected
-removing batery
- the asus emirgency restore using usb and pressing cmd+home
- removing the cmsd battery(not sure about the name) the small round one inside the laptop
nothing has worked so far....
any ideas?
asus r510jk motherboard asus x550jd
thanks
black screen after bios change
Try this trick :
Remove battery an press on holding power button for 1 minute then connect adapter to it followed by pressing power button. Now make a shutdown ,connect battery and adapter.
