Hi
I have a MSI GT663 Gaming laptop and recently tried updating the bios to the version i downloaded from MSI suppport. During the update my laptop lost power and now when i try to boot the screen stays black but the fan runs quite fast and the cd drive sounds like its functioning.
I have tried resetting bios by removal of bios battery and power sources and rebooting but still the same. At first after resetting bios when power button is pressed the power light flashed for a second then nothing and then i press power button again and it starts the fans and some noises but still black screen.
The motherboard is MS16F1 and the bios is 686 AMIBIOS CL756560 which i tried to update to E16F1IMS.10L version.
I have read many conflicting help guides but none that i tried have worked.
If i cannot access bios could i flash bios via usb floppy as it states in the manual that USB Flash Boot Yes, USB floppy boot up DOS only .
I have tried copying bios onto Fat32 usb and powering on but nothing also tried the same holding ctrl and home. I tried emulating floppy drive onto usb stick and copy bios file into root and power and and the same holding ctrl and home.
Any help much appreciated
Many thanks
Jamie
MSI GT663 MS16F1 Corrupt BIOS
USB floppy means literally that, a floppy disk drive with an USB connector. The floppy disk needs to have DOS and the bios file AND autoexec.bat file with the proper command to flash the bios. I would send an email to MSI tech support stating what happened, they should be able to give you the proper procedure to revive your laptop.
