SONY PCG-505TL failed bios update--stuck
slicknick0001
i have a the ultraslim sony (PCG-505TL)with the docking port and i wanted to update to windows xp. so i went to teh sony webpage and downloaded the updates. when i went to flash the bios it went to 70 percent complete and went to a black screen. i tried restarting, does not load up, black screen, but the computer does seem to turn on and make a few noises. any help as to what i should do from here would be apreeciated, thanks.
You're stuck. I wish I had a better answer for you. Unfortunatly you have two options.
Use these guys:
http://www.laptopbios.com
or call sony and buy a new motherboard.
Joe
Use these guys:
Joe
soupy
- Absentee administrator
Joe, if you want to plug your company, DON'T pretend to recommend it as an impartial visitor.
Because you've been genuinely helpful in these forums, I'm not going to hammer you for this, but please don't let it happen again.
