Help me.
I have a sony Vaio PCG F560 laptop, it came with 98SE, i upgraded to XP 5 months before and it was working fine today i downloaded the BIOS upgrade from
http://www.ita.sel.sony.com/support/pc/pcgf540f560/
http://ciscdb.sel.sony.com/cgi-bin/swu- ... ADERFILE=1
when i installed it it asked me to insert a floppy and when i rebooted it asked me whether to upgrade the bios, i said yes.
at end of the process suddenly all gone, no screen display, no power light, but i can hear the fan sound, i am unable to shutdown the pc for that i need to manually remove off the power supply from wall.
please help me to recover from this.
Sony laptop BIOS Help needed
This is your problem:
You duplicate posting in "My Motherboard Is Dead" has been deleted.
In our experience when you mis-flash a Sony laptop there is little you can do except take it to a Sony service centre.arvinth wrote:I have a Sony Vaio PCG F560 laptop
Your BIOS chip is located on the bottom of the laptop almost center under a small door.
The BIOS chip is mounted (soldered) onto a small removable "sub-board". You can either try and find that whole sub-board and replace it, or you can contact me and we'll reprogram your BIOS chip and remount it to your sub-board.
It's not free, there is work involved, but it's nowhere close to what Sony is asking for the repair.
Please pay close attention to the small white "dots" on the BIOS sub-board and the motherboard, you HAVE to line them up when you're re-installing the BIOS.
Joe K
[email protected]
Joe K
[email protected]
