Hi just updated to a AMD Turion mobile ML-42 but can only boot laptop with power plugged in - also have to use Rightmark utility to adjust voltage and cpu mulipler.....1.2v and X12 - it works fine at 2.4ghz and fine if you unplug after booted - i suspect the bios needs a tweek - anyone any ideas?
startup bios is 1.000v (FID)and Multiplier of 4.0x (VID)
BIOS Date: 05/04/06
BIOS ID: 63-0100-000001-00101111-050406-SiS755-1ABXK004
OEM Sign-On: BIOS Date: 05/04/06 Ver: 212
Chipset: SiS 760 rev 3
Superio: ITE 8705/SiS 950 rev 2 found at port 2Eh
OS: WinXP SP2
CPU: AMD Turion(tm) 64 Mobile Technology ML-42 LanCaster SH-E5
WIN XP 5.1.2600 Service Pack 2
BIOS ROM In Socket: Yes
BIOS ROM Size: 512K
Memory Installed: 1024 MB
Memory Maximum: 8192 MB
Memory Slot 01: 512 MB
Memory Slot 02: 512 MB[/b]
