Hi Friend i have a problem one of my friend has done something by which it displayes a message "This is Raj Computer......" when i switch on my laptop and then it boots into operating system.
Can anyone one help me to how to remove this message.
Bios
If the welcome text is generated by the bios during bios boot time,
re-flashing your bios with original bios should cure the problem. Make sure you flash a correct bios.
Just wondering if the text is generated by a program that acts as a opetating system initialization routine. If so, then reinstalling the operating system should cure the sotuation.
