Unfortunately what appeared according to WinPlash to be a good BIOS upgrade bricked the Vaio VGN-FE41Z laptop!
I had already prepared a bootable Phoenix Crisis Recovery diskette (and CD) so I figured it would be sorted out quickly.
However it turns out that either this BIOS doesn't support the boot-time hot-key, or the key combination on this model is different from the expected Fn+B / Win+B options.
Has anyone heard of, or done, a crisis recovery procedure on a Vaio laptop or notebook?
Sony Vaio Phoenix Crisis Recovery Sequence?
Hello I have the same problem, none of key combination seems not to be working? Has anyone got any solution for dead sony vaio laptop going into crisis recovery mode please?IntuitiveNipple wrote:Unfortunately what appeared according to WinPlash to be a good BIOS upgrade bricked the Vaio VGN-FE41Z laptop!
Let us now if you ever recover dead sony vaio laptop, my model is sony vaio tx5xn.
Thanks for any help guys!!!
Use Ctrl + Esc or Fn + Esc. Or Alt + Esc before power onstkrup wrote:Hello I have the same problem, none of key combination seems not to be working? Has anyone got any solution for dead sony vaio laptop going into crisis recovery mode please?IntuitiveNipple wrote:Unfortunately what appeared according to WinPlash to be a good BIOS upgrade bricked the Vaio VGN-FE41Z laptop!
