Does anyone know if the bios update at Fastfame China...
650BX 2 Mbit BIOS 1.40: http://www.fastfame.com.cn/HOME/BIOS/IN ... 40.bin.rar
09/25/2001-i443BX-W977TF-650BX_14C-00
Release date:2001/09/25 Ver:1.40
solves the problem of single-sided 256MB SDRAM chips being recognized? I have a stick of single-sided and it only recognizes 128MB. Someone mentioned updating the BIOS would solve this problem.
Any ideas? I don't want to update the BIOS unless this is solved.
03/30/1999-i440bx-19981010c-00
Single sided 256MB module will not work on most older chipsets like i440BX. You must use double sided 256MB module.
http://www.wimsbios.com/phpBB2/viewtopic.php?t=3583 in the RAM Compatibility forum could be of interest.
Don't hijack threads! You should have started a new thread in the RAM compatibility forum. Soupy will be on your tail.....
