Dr Morg,
Do you still have Thinkpad configuration utility installed in XP? Check if it shows USB and IRDA enabled.
Yes, I have this utility.Sharedoc wrote:Dr Morg,
And there USB and IrDa enabled.
Drivers for it installed correctly and funtional without conflict and errors.
IBM ThinkPad 600E (2645-4AU) PIII 600 @ 598.2MHz /13.3"/CD-ROM/160Mb/40Gb/56k
@ [FSB_mod] => (Current ~99.7MHz)
@ [SS_mod] => Enable Intel SpeedStep technology
@ [DS_mod] => Start SpeedStep
@ [Volt_mod] => Takes 0.20 volts off Vcore (Current 1.35V)
beatoem
- Chip off the ol' block
"Sharedoc",hows the 750 cpu going thus far?,mine is running beaut,@650+810 mghz,good to see others hack right into their thinkpads
i have a question though,with the cache enabler does your cahe automaticaly load with the powerleap program or do you have to click on the icon to activate the cache?why i ask is because in xp pro,the software doesn't seem to load into the registry unless i click on the icon in desktop
am i'm pondering if thats the case with your setup hows to load the rege hive so as the cache software auto loads in win xp?
I took this utility. It installs something in xp so it is alive in windows everytime.
http://www.powerleap.com/downloads/util ... tility.zip
test it.
it is easy to use.
test it.
it is easy to use.
Powerleap autoloads by using a setting on one of the tabs.
It occasionally fails to load giving a strange error "failed to load ring component" of something similar (I'll get the exact error next time it occurs)
The cache utility Holgi128 is referring to made my pad BSOD last time I tried it.
beatoem, if you are still having issues loading powerleap at boot try adding this to your registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
create a string value called powerleap the add the full path to the exe as the data.
Thinkpad T20 - 900 MHz (Looking for 1 GHz) 512 Mb - 40Gb 5200rpm - Mini PCI wireless Mod installed behind LCD - (Looking for Slim DVDRW)
I've just photo errors on selftest:Dr. Morg wrote:Yes, I have this utility.Sharedoc wrote:Dr Morg,
http : / / w ww.metacom.ru/~alexmorg/CPU/Pic(9).jpg
http: / / w ww.metacom.ru/~alexmorg/CPU/Pic(9).jpg
http: / / w ww.metacom.ru/~alexmorg/CPU/Pic(10).jpg
Could you tell me what is wrong?
Those codes indicate an error on the USB and Serial devices and the FRU code suggests replacing the Systemboard.
I know, but this errors was befor I mod my TP!Katch wrote:Those codes indicate an error on the USB and Serial devices and the FRU code suggests replacing the Systemboard.
They arrise only in selftest, but never in Windows!
WinXP says, that all working fine.
This some scrinshots:
And some system information:
Modified: 2005-04-22 15:29:08
******************************* SYSTEM SUMMARY *******************************
OS information: Microsoft Windows XP
OS version: 5.10.2600 Service Pack 2
Processor: x86 Family 6 Model 8 Stepping 6
Memory: 163 184 kb
BIOS version: 99-11-20 - INET36WW
Machine type-Model: 26458AU
****************************** BIOS INFORMATION ******************************
System unit serial number: 78GHBZ0
System board serial number: J1Y268192X6
Slave controller version: 99-07-16 - IHHT08WW
***************************** DRIVE INFORMATION ******************************
Logical drive: C:\
Drive type: Fixed drive
Drive size: 6 322 880 kb
Drive free space: 909 124 kb
Logical drive: D:\
Drive type: CD-ROM drive
Drive size: 0 kb
Drive free space: 0 kb
***************************** OTHER INFORMATION ******************************
Power scheme: High System Performance
********** AC settings **********
Turn off monitor: After 60 minutes
Turn off hard disks: After 20 minutes
System standby: After 60 minutes
********** Battery settings **********
************************* SYSTEM DEVICE INFORMATION **************************
Device class: Accessibility options
Device status: Disabled
No resources used
Device class: Serial port
Device description: Ïîñëåäîâàòåëüíûé ïîðò (COM2)
Driver provider: Microsoft
Driver date: 7-1-2001
Driver version: 5.1.2600.0
Device status: Enabled
Resource
I/O address: [03F8 - 03FF]
IRQ: 4
Device class: Parallel port
Device description: Ïîðò ïðèíòåðà (LPT1)
Resource
I/O address: [03BC - 03BF]
Device class: TrackPoint
No resources used
Device class: Audio
Device description: Àóäèî êîäåê Crystal WDM
Driver version: 5.1.2535.0
Resource
I/O address: [0530 - 0537]
I/O address: [0388 - 038B]
I/O address: [0280 - 0293]
DMA: 3
DMA: 0
IRQ: 7
Device class: Infrared
Device description: IBM ThinkPad áûñòðûé ÈÊ-ïîðò
Driver provider: National Semiconductor
Driver date: 3-17-2001
Driver version: 1.0.0.0
Resource
I/O address: [03E8 - 03EF]
DMA: 1
IRQ: 5
Device class: Joystick port
Device description: Èãðîâîé ïîðò Crystal WDM
Driver date: 9-23-1998
Driver version: 5.0.0.0
No resources used
Device class: Internal modem
Device description: ThinkPad Digital Signal Processor
Driver provider: IBM Corporation
Resource
I/O address: [0130 - 013F]
DMA: 6
IRQ: 11
Device class: PCI Device Setup
Resource
IRQ: 11
Device class: Device Bay
Resource
I/O address: [0170 - 0177]
IRQ: 15
Device class: Docking station
No resources used
What now can you say?
Thanks!
Beatoem,
Yeaterday I installed 750MHz processor back and I am running it at 810MHz now. It is stabile on normal use but under heavy load testprogrammes it generates errors after a few minutes of full load due to overheating.
I am running it now standard Vcore = 1.60V. I'll try to lower Vcore if it helps.
I am using Powerleap CPU control panel and I select from Options leaf "automatically start at startup". I have detected best NOT to select MTRR related boxes from Advanced settings leaf.
My 700MHz processor is better, because it is stabile at 829MHz.
IrDa looks like work, but it's not work!Sharedoc wrote:Dr Morg,
Does USB port work?
Does Infrared work?
USB sometims work, but it turnes off when Windows start.
I'm try to bootup with USB Flash drive and it work for about 30-60 seconds after Windows start. After that it turns off again.
I'm try again, but it have no effect.
So, I don't understand work it or not.
What about IrDa,- I'm try to connect my SonyEricsson T610 via IrDa, but it found no devices around it.
What can you tell me about it?
Big thanks!
My t610 is difficult to connect via Idra at the best of times. Try keeping the phone about 20cm from the laptop.
The fact that the usb issue is intermitent makes me think its a hardware problem. I'd maybe check the contacts in the USB port are all sound etc.
The errors in the system utility are a little concerning though. NOt sure how best to proceed. I'd be tempted to check all the settings of the laptop using the ps2.exe config utility (you can get it from IBM somewhere)
Put it on a floppy boot disk and you can check the power saving modes, irq and dma assignments etc of all the devices on the laptop.
Dr Morg,
Looks bad, propably you have hardware fault somewhere on your mainboard.
http://panopticon.csustan.edu/thood/pdf ... manual.pdf
I've just trying to connect my T610 as you say, but results was the same as before...Katch wrote:My t610 is difficult to connect via Idra at the best of times. Try keeping the phone about 20cm from the laptop.
I don't know wat's wrong with it..
I have not found this utility.Katch wrote: The fact that the usb issue is intermitent makes me think its a hardware problem. I'd maybe check the contacts in the USB port are all sound etc.
Can you upload it somewhere or give me the link?
I have no floppy on my TP600E, but I think I can to boot up with my bott CD with DOS and Norton Commander.Katch wrote: Put it on a floppy boot disk and you can check the power saving modes, irq and dma assignments etc of all the devices on the laptop.
Thanks!
I've already read it, but it doesn't give me some needful information, helps to fix it.Sharedoc wrote:Dr Morg,
I think, that the problem not only in hardware.
Where can I see actually work of all ports in TP?
Thanks for your answers!
