If you're convinced its not hardware here is how I would proceed.
Fresh Clean Flash of the BIOS to highest revision
Initialise in the BIOS to restore all defaults (you will need to redo the cache disable hex)
Use the ps2.exe thinkpad dos configuration utility to make sure everything is on the right addresses and irq etc.
Clean install of XP.
If it still fails its a systemboard error.
I'd follow Sharedocs gut instinct on this. There is something wrong with the motherboard of your pad.
beatoem
- Chip off the ol' block
Holgi128 wrote:I took this utility. It installs something in xp so it is alive in windows everytime.
http://www.powerleap.com/downloads/util ... tility.zip
test it.
it is easy to use.
I tried the speedstep software from Intel but no dice. Said my P3's maximum speed was 600 mhz though its a 750(un-modded). It did detect it as speedstep compatable though.
It seems, I have found the reason on which does not work USB!Katch wrote:If you're convinced its not hardware here is how I would proceed.
I looked through the list of interruptions in system and have seen a strange situation, - 9 interruption has been appointed to five devices!!!
The list of interruptions which has given out SiSoftware Sandra:
0: The system timer
1: Standard (101/102 keys) or keyboard PS/2 Microsoft Natural
3: ThinkPad Modem
4: A serial port (COM1)
5: IBM ThinkPad fast ÈÊ-port
7: Audio codec Crystal WDM
8: CMOS and hours
9: Crystal SoundFusion (tm)
9: Intel (r) 82371AB/EB PCI - USB the universal host - controller
9: Microsoft ACPI-compatible system
9: Texas Instruments PCI-1251 CardBus the controller
11: ThinkPad Digital Signal Processor
12: IBM PS/2 TrackPoint the trackball
13: The processor of the numerical data
14: Primary channel IDE
15: Secondary channel IDE
In WinXP conflicts has not caused, but also USB does not work, though the sound works perfectly! I did not check PCMCIA slots, since I have no PCMCIA cards.
Whether is it possible in BIOS to renominate interruptions?
Probably, it can be made in section Extended CMOS-> PCI IRQ Data.
What can you say about it?
Beforehand I thank you for the help!
IBM ThinkPad 600E (2645-4AU) PIII 600 @ 598.2MHz /13.3"/CD-ROM/160Mb/40Gb/56k
@ [FSB_mod] => (Current ~99.7MHz)
@ [SS_mod] => Enable Intel SpeedStep technology
@ [DS_mod] => Start SpeedStep
@ [Volt_mod] => Takes 0.20 volts off Vcore (Current 1.35V)
TP600s use extensive interrupt sharing. It is only an issue when using Linux not Windows XP.
If you want to disable stuff you don't need and reassign IRQs etc get the DOS configuration utility from the IBM downloads section for the TP600.
Thinkpad T20 - 900 MHz (Looking for 1 GHz) 512 Mb - 40Gb 5200rpm - Mini PCI wireless Mod installed behind LCD - (Looking for Slim DVDRW)
I've download PS2 utility from site IBM here [570Kb].Katch wrote:TP600s use extensive interrupt sharing. It is only an issue when using Linux not Windows XP.
Has tried to understand, but and could not change IRQ on necessary me.
Simply disable device, - not the decision of a problem, IMHO!
Some details:
Code: Select all
Command Syntax : PS2 ? IRQ
Description : Display the current IRQ assignments.
Current State :
System IRQ Assignment
IRQ Level
3 4 5 7 9 10 11 15
Serial-A (3 or 4) : X
Parallel (5 or 7) : O
Internal Modem First IRQ : O
(3, 4, 5, 7, 10, 11, or 15)
Internal Modem Second IRQ (3 or 4) : O
WSS/Sound Blaster/FM : O
(5, 7, 9, 10, 11 or 15)
MIDI port (5, 7, 9, 10, 11 or 15) : X
IR (3, 4, 5, 7) : O
Second IDE (System) : O
Second IDE (Docking station) : X
Third IDE : X
PCI IRQ : O
where O: Currently assigned,
X: Will be assigned after "Enable" is selected,
*: Conflict with another device.
Code: Select all
Command Syntax : PS2 PCIIRQ Disable
First IRQ (Second IRQ) (Third IRQ) (Fourth IRQ)
Valid IRQs : 3|4|5|7|9|10|11|15
Assigned IRQ(s) : 11
Description : This command is to reserve the IRQ(s) for PCI devices.
When 'Disable' is specified, PCI device may not work
properly. To see the current system IRQ assignment,
type "PS2 ? IRQ".
Code: Select all
Command Syntax : PS2 IR Enable|Disable
ADDress 1|2|3|4
DMA 0|1|3|Disable
IRQ 3|4|5|7
COMADDress 3F8|2F8|3E8|2E8
Current State : Enable
When "Enable" is selected, following parameter will be effective:
ADDress : 1
DMA : 3
IRQ : 4
COMADDress: 3F8
Description : Use this parameter to set up the IR port.
As for "ADDress",
1 : COM1 (3F8h, IRQ4)
2 : COM2 (2F8h, IRQ3)
3 : COM3 (3E8h, IRQ4)
4 : COM4 (2E8h, IRQ3)
To use IR High-Speed mode, assign any DMA channel
for this device.
Code: Select all
Command Syntax : PS2 IMODEM Enable|Disable
IRQ First IRQ (Second IRQ)
DSPADDress 130|350|770|DB0
IMODEMADDress 2E8|2F8|3E8|3F8
DMA 0|1|6|7
Valid First IRQs : 3|4|5|7|10|11|15
Valid Second IRQs : 3|4|Share
When "Enable" is selected, following parameters will be effective:
IRQ : 10 3
DSPADDress : 130
IMODEMADDress : 2F8
DMA : 7
Description : Use this parameter to set up the telephony function.
The IRQ sharing function may not be supported,
depending on your operating system.
Refer to your manual for details.
Code: Select all
Command Syntax : PS2 SERA Enable|Disable
ADDress 1|2|3|4
Current State : Disable
ADDress : 1
Description : Use this parameter to set up the serial-A port.
As for "ADDress",
See difference? What can you say?
Also, I'd like to confige processor speeds, but my attempts to make it have not crowned success!
This is how it must work, but no work (I'm really try it)...
How can I edit it?
Code: Select all
Command Syntax : PS2 SPeed Fixed MAX|Medium|Slow [AC|DC]
Auto Medium|Slow [AC|DC]
Current State :
High power mode : Fixed MAX
Auto power mode : Auto Slow
Customized power mode : Fixed MAX
Description : Select one of the processor speeds from the list:
1. Fixed MAX (Highest Performance)
2. Auto Medium
3. Auto Slow
4. Fixed Medium
5. Fixed Slow
Specify AC when you change the processor speed for an AC
operation.
Specify DC when you change the processor speed for a battery
operation.
When you do not specify [AC|DC] option, the current power
source(AC or Battery) is selected.
Whether there is an opportunity to change IRQ of the certain device?
If so, how it can be made?
And why interruptions in Windows are allocated at all not so how the PS2 utility shows?
Thanks!
Put the code into notepad and save it as a setup.bat onto the cd that you boot from in the ps2.exe directory.
Disable everything (you may need to add devices to my list)
Then set up the devices address and ports to your preference (You may find it handy to add REM lines telling you what you are setting them to)
Boot from the disk then just type setup from the ps2.exe directory.
The process is quite slow (at least it was when I did it from floppy) but afterward when you reboot the Laptop will make a strange beep before rebooting - if it does you know it made the changes.
The reason Windows XP will make changes when you reboot is that it has the IRQ values etc coded in the registry from the installation. Ideally you want to make the changes then make a fresh XP installation.
I've played with the CPU Speed thing at its syntax is like this;
Code: Select all
ps2 imodem disable
ps2 parallel disable
ps2 jstick disable
ps2 serial disable
ps2 SERA disable
rem ** This sets the IR Port COM1, 0x3f8, DMA 4, IRQ 4
ps2 ir address 1
ps2 ir dma 3
ps2 ir irq 4
ps2 ir comaddress 3f8
ps2 ir enable
rem keyboard repeat rate
ps2 kr fast
rem This sets the Soundcard chip cs4232 to, 0x530, irq 5, dma 0 1
ps2 audio address 530
ps2 audio irq 5
ps2 audio sbaddress 220
ps2 audio dma 0 1
ps2 audio enable
ps2 audioctrl address 538
ps2 audioctrl enable
Code: Select all
ps2 speed Fixed MAX AC
ps2 speed Auto Medium ACThinkpad T20 - 900 MHz (Looking for 1 GHz) 512 Mb - 40Gb 5200rpm - Mini PCI wireless Mod installed behind LCD - (Looking for Slim DVDRW)
Has anyone had any luck overclocking a P3 800 or 850? Seems everyones got a 700 or lower. I know Sharedoc overclocked a 750 but his was unstable. I have yet to attept it on my 750 just cuz of that.
I have waited now several monthes to find a 800 or 850MHz-MMC2-PIII in European eBay, but none has been available at a reasonable price.
I am not able to buy from US eBay, because sellers normally don't deliver to Europe and they require PalPay which is useless in Europe and I would not like to take it. I know there are 800MHz PIII's for sale at a reasonable price <115 USD.
I need to find a seller that ships to Europe and I could pay with a normal credit card (Visa).
I just finished my 750 Mod and testing stability at the moment. It seems to be ok but I have noticed my memory bandwidth has actually dropped slightly from the Cel 600...?
Its strange the way it doesn't always select the 7.5 multiplier. Seems to resume from a hibernate intact though.
Hm... I don't know why it's not work, I'm try several times, but results was the same...Katch wrote:Put the code into notepad and save it as a setup.bat onto the cd that you boot from in the ps2.exe directory.
The reason Windows XP will make changes when you reboot is that it has the IRQ values etc coded in the registry from the installation. Ideally you want to make the changes then make a fresh XP installation.Code: Select all
I've cut it...
It's not take effect on my TP...Katch wrote:Code: Select all
ps2 speed Fixed MAX AC ps2 speed Auto Medium AC
Also, I have troubles with SpeedStep on booting:
1. Sometimes when I start up my TP, it Error 108 arrise,- it's mean, that FSB generator not starts. When I power off, than power on again,- TP boot great.
2. When TP start,- it boot on lower speed (about ~540MHz), and it not depend on way of boot (AC adaptor or battery). When Windows boot,- PowerLeap enabled L2 cache,- than CPU FSB increase to ~650Mhz.
How can I fix it?
Thanks!
Dr Morg,
You need to go back to the start of all this. Everyone here who has given their educated opinion, based on the few facts available, have advised it is entirely likely that the systemboard has a hardware fault.
Replace the board or check the integrity of every circuit, controller and component.
I have also encountered 108 error sometimes with the 700MHz-PIII when I use high fsb, over 115 MHz, but with 108 or 100 it does not appear. Also with the 750MHz-PIII it does not appear regardless how high fsb.
About SS kicking in so late as Windows and Powerleap it is true. 90% of the times it kicks in during/after Powerleap run, but 10% of cases it shows higher speed already in the Powerleap opening window.
I'm already bought two another MotherBoards on eBay.Katch wrote:Dr Morg,
When they arrives me, I'll post here my experience with replacement.
Thanks for your help!
My TP work with 108 MHz FSB speed, but error 108 arrise sometimes, not depend on nothing!!!Sharedoc wrote:I have also encountered 108 error sometimes with the 700MHz-PIII when I use high fsb, over 115 MHz, but with 108 or 100 it does not appear. Also with the 750MHz-PIII it does not appear regardless how high fsb.
I've try to disable internal 32Mb RAM, but it's not take effect.
I don't know, why this error arrise.
Maybe, reasone of this error in problematic motherboard, and not in FSB mod?
In BIOS my PIII 600 with FSB_mod and SS_mod looks like PII 550:Sharedoc wrote: About SS kicking in so late as Windows and Powerleap it is true. 90% of the times it kicks in during/after Powerleap run, but 10% of cases it shows higher speed already in the Powerleap opening window.
PowerLeap shows, that it has multiplier 5, but CPU FSB ~650:
CPU-z shows, that multiplier is 6:
Indications of what program to count true?
Why in BIOS CPU is always displayed as PII 550, but never PIII 650 (SS mod not work there, I think...)?
Thanks again!
