Good day all.
I am looking for help and advice regarding making a new custom bios for my Tyan Thunder K8SD Pro (S2882-D) motherboard.
The above motherboard has a build in Silicon Image SteelVine Sil3114CTU SATA Raid Controller.
From what I have read is that the ROM used for the Sil3114 is part of the main system bios.
The current Sil3114 rom is v5.0.64, but I am having some issues and would like to try and update the rom to v5.0.73.
Tyan Thunder K8SD Pro (S2882-D) v3.09 BIOS: ftp://ftp.tyan.com/BIOS/2882-D_309.zip
Silicon Image SteelVine Sil3114CTU Rom v5.0.73: http://www.siliconimage.com/docs/BIO-00 ... 0_5073.zip
So can anyone please advice if this is possible, and if so, how I would go about doing this?
Thanks for your time.
Best Regards.
Custom bios for: Tyan Thunder K8SD Pro (S2882-D)
patching in the new SIL rom is possible.
just 2 more questions:
1. which kind of bios do you need? RAID or IDE? (check here for a description)
2. which version do you need? check the above link and report back with the version you want.
