Hi
Need bios upgrade for the following: 04/05/99-i440BX-W977TF-2A69KQ19C-00
Thanks in advance
Bios Upgrade Needed: 04/05/99 - i440BX
QDI motherboard.
...if you bothered to check the info on this site (Wim's) it would tell you that your BIOS ID is for QDI P6I440BX/B1.
