I have a problem with an acer aspire 3004 SiS M760GX Bios 2.27.g8.
Driver software version v 3.93 windows XP
My monitor has a 1920x1080 resolution.
In the computer is this resolution 1920x1080 available. When I set this resolution, the computer makes it, but he did not sent it correct to the monitor.
The result is, that the monitor is set to 1680x1050 resolution and I do not see the full desktop on the monitor.
Do you think, that a vbios update will help here also?
1920 x 1080 on Acer Aspire 3004 with SiS M760GX chipset
The vbios updates we have are for 1440x900 maximum. I'll see if there's an update for the M760GX that supports 1920x1080. It's one we normally not do because it usually disables output to the internal monitor of your laptop.
