Request for patched bios for MS-6719 revision 1.0
Video, SCSI, modem, CDROM/CDR/CDRW, etc.
jarodcanal
The patched bios available on your page is for MS-6719 revision 1.1 motherboard.
Unfortunately, I have a Microstar MS-6719 revision 1.0, which uses a different bios.
The direct link to the provider bios is (bios version 1.15):
http://www.medion.com/gb/service/_light ... &hgt=12835
Please, can you provide a patched bios to get 1440x900 support on this SiS 651 motherboard.
Thank you.
Regards
unpack before flashing. use at own risk.
W6719mdp.zip
MED6719 patched bios with SiS 6325 VBIOS 2.30.01
(212.53 KiB) Downloaded 786 times
jarodcanal
Thank you very much.
I flashed the bios with your update and it now reports VBios 2.30.01.
Unfortunately, I am using SiS univga 3.73 driver under winXP, and it seems does not offer 1440x900, max resolution available is 1280x1024.
I also update screen driver, but no 1440x900 support.
Regards
BIOS Guru
Please uninstall the VGA driver, reboot and install it again.
