Hello good people!
I'm in search for BIOS update for this bugger http://www.nec-computers.com/support2/p ... olumbia_mt
I'm trying to run 1680x1050 on it with the latest VGA and LCD drivers installed ... I can see desired resolution, but can't set it.
The VBIOS is 1.something.something, so that seems to be the problem.
I've tried generic gigabyte BIOS for ga-8siml ver.1 ... the flash utilitie tried to load the BIOS and gave "wrong BIOS ID".
After visual inspection the motherboard is gigabyte ga-8siml ver.1 and in the bottom left corner on a white background there is NF and rev.1
I think that's the MB http://www.befr.ebay.be/itm/Packard-Bel ... 541efaeabf
MB ID in AIDA64 is 62-1029-001199-00101111-040201-SiS650$NECC000_8SIML V3.0K
Current BIOS version 8SIML V3.0K
NEC Powermate ml4 BIOS (1680x1050 VGA)
The maximum resolution any known updated vbios will give you is 1440x900. In your case the only way to reach the desired resolution is adding a video card that does support that resolution.
