How bout it?
My problem- when i put in my geforce4 ti4200 and turn on the system, the monitor doesn't turn on. When i take out the geforce and plug the monitor into my integrated sis card, everything works fine. The geforce has worked perfectly for about 5 months until last week. Do i need to update my bios?
BIOS-Info, c't/Andreas Stiller, V. 1.5 10/00
Computer ID : FC, SubTyp: 02, BIOS-Level: 116
Rechnertyp : AT,typ ??, Konfigurationsbyte $70
Maustreiber : Microsoft kompatibel, Version: 08.00
Maustyp : InPort-Maus auf IRQ2
Bus : ISA
Hauptspeicher : 640 KB, davon verfügbar : 640 KB
Extended Memory : 1024 KB
BIOS Datum : 05/15/02
Award BIOS gefunden : Award Modular BIOS v6.0
Award ID-String : 05/15/2002-SiS650-P4S266VX
Board/BIOS-Version : BIOS Revision 1002
OEM : AsusTek
URL : http://www.asus.com + www.asuscom.de
Chipset : SiS650
INT-13h BIOS Extension: nein
PnP (ACFG,ESCD,DMI) : PnP V1.0/ESCD, DMI V 2.3, SM V2.3
Weiter mit D)MI-Info,E)SCD-Info, sonst Exit:
Most probably, the card went bad.
The board is Asus P4S266VX.
I can't find any bios for P4S266VX on www.asus.com, or anywhere else, for that matter....am i looking for the wrong thing or something?
The name is P4S266-VX. It looks to be an OEM board for Sony
Used in the following Vaio models:
PCV-RX600P, PCV-RX700P, PCV-RX700(CTO)
PCV-RX730 and PCV-RX731
PCV-RX750/RX750P, PCV-RX751, PCV-RX752, PCV-RX753, PCV-RX755 and PCV-RX756
PCV-RX760/RX760P, PCV-RX761 and PCV-RX762
PCV-RX770/RX770P
PCV-RX780G and PCV-RX781
PCV-RX770/RX770P
