my motherboard is dead and i can not find a bios immage ?
italianrobyboy
Super-duper Dumbass
09/01/2000-693-596-W977E-M7-AV693C-00
Where i can find a new bios immage ?
NickS
BIOS Bodhisattva
http://www.jama.com.cn/jama/drivers/bios/index.htm
Hmmm... not listed there - I'll look in the archives.
[edit]Note: a few Jama boards are ECS clones [/edit]
[edit]product page: http://www.jama.com.cn/jama/product/m7-av693.htm[/edit]
NickS
BIOS Bodhisattva
OK, looks quite like ECS M6-PVAP-A+.
(above) Jama M7-AV693
Image BUT NOT QUITE THE SAME...
ajzchips
El cheapo dude
Yep... I did investigate, too, but the ECS board has the 694X chipset, although both boards are VERY similar.
italianrobyboy
Super-duper Dumbass
Nick thanks for your time. I not find a image for my bios could u send me please. Ajzchips do u think i can use the same bios using bbot block utility ?
ajzchips
El cheapo dude
I'm not sure I understand your question.
italianrobyboy
Super-duper Dumbass
I USE M6-PVAP-A+ BIOS. PC START UP BUT NOISY TO COUNT THE RAM ONLY FIRST DIMM IS RECOGNISED THE SECON AND THIRD NOT WHY ?
NickS
BIOS Bodhisattva
Could be because the BIOS is for 694 not 693. I have not found an alternative (ECS) BIOS match yet.
italianrobyboy
Super-duper Dumbass
Where i can find a good image for my motherboard ?
italianrobyboy
Super-duper Dumbass
i used the ecs bios but the 2 e 3 slot for dimm didn work ? why ? same possibility to find a correct image for my bios ?
ajzchips
El cheapo dude
I sure hope you saved a copy of your original BIOS 8O
Anyway, who told you it was safe to flash the ECS BIOS???
italianrobyboy
Super-duper Dumbass
The jama web site didn t offer a bios image. Ecs is not correct what can i do ?
ajzchips
El cheapo dude
You can flash back to the original JAMA BIOS you saved before flashing.
italianrobyboy
Super-duper Dumbass
I didn t have the original bios. I hape to be same possibility to will have a new bios.
ajzchips
El cheapo dude
You could try looking for help here:
[email protected]
[email protected]
BTW, I do suppose the flasher "asked" you whether you wanted to save a copy of your previous BIOS...
