I just reinstall Windows XP Pro on a motherboard with on-board soundcard but without VGA on-board.
I didn’t look at the drivers before to erase the operation system.
Now I can not find the sound card drivers anymore.
I can not identify this motherboard, please help.
The string from BIOS Agent is as follow:
Program: eSupport.com BIOS Agent Version 3.34
BIOS Date: 12/11/02
BIOS ID: 62-1211-001131-00101111-040201-SiS64X-930
OEM Sign-On: Release 12/11/2002
Chipset: SiS 646 rev 0
Superio: ITE 8705/SiS 950 rev 2 found at port 2Eh
OS: WinXP SP1
CPU: Intel(R) Pentium(R) 4 Processor 1800 Mhz MAX: 300 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 512 MB
Memory Slot 01: 256 MB
Memory Slot 02: 0 MB
Memory Slot 03: 0 MB
Memory Slot 04: 0 MB
Thanks in advanvce for your answer.
Help to recognize this motherboard, please.
worldwidecom2106
worldwidecom2106
Please give me the link from where to download these drivers.
Thanks in advance.
Thanks in advance.
You can try to identify the board at the PC-Chips Lottery which should link to the drivers if the board is too old for the main PC-Chips website.
http://www.pcchips.com.tw
http://www.ecs.com.tw
Are you sure that's SiS64X-930 and not -938 ?
Try first www.realtek.com.tw and www.cmedia.com.tw
-> The one or the other driver should work
If not then go to http://download.sis.com
worldwidecom2106
Thank you.
I shall try today the websites and all the drivers I find follwing your instruction.
The bios said is 930 when the computer boot.
I shall let you know the result.
worldwidecom2106
I alrteady tried yesterday all the drivers.
CMedia 9761 worked on this motherboard.
Thanks all of you.
Thanks all of you.
