CAN ANYONE HELP I CAN FIND ALL GIGA BYTE GA-7ZMM?
BUT THE MMP IS NOT EASY TO FIND
DOUPT IT COMES WITH PAPER MAN AS IT'S FROM A TINY MACHINE??
NEED MANUAL FOR tiny GA-7ZMMP
zonxar
- Master Flasher
Gigabyte GA-7ZMM manual can be found here (and will likely cover the GA-7ZMMP as well):
http://www.giga-byte.com/Motherboard/Su ... A-7ZMM.htm
The Tiny system would not likely come with a motherboard manual, only a system user's manual. Compare the information in the manual with your board to determine if it matches.
The only Gigabyte site with info on your board is their Russian one:
http://www.gigabyte.ru/new/main.php?pag ... b&prod=224
Hi there,
Is the an updated Bios for the GA-7ZMMP-TU ? I have olf Time PC with this in currently adding memory may as well update Bios when at it.
Anyone know advantages of new bios if available ?
Also have english manual from original system/ driver CD if anyone needs.
Cheers,
Mully
Cheers,
Mully
send the manual to [email protected]
I'll try and find what the last released bios for the Time/Tiny version of this board is.
Guys!
The sotec bios which is on the russian site works a treat! The only thing is you have to tell the flash utility to ignore the bios ID string cos they are different. SO MAKE SURE you download the RIGHT BIOS cos obviously once you tell it to ignore the string then you can potentially total your board. But having said that it really works well and fixes things like XP and V-large HDD's...
The header pin-outs are indeed the same for all boards in this series. Also all the necessary drivers can be collated from various other parts of the Uk Gigabyte site including one for the built in TNT2 card. So all your support problems are over.
Now on to my little problem... In THEORY this board should be able to run with a 133Mhz FSB and therefore be able to boot at least some of the XP series of CPU's. (I already have 133mhz memory) To do this you have to fiddle with SW1 - and according to the legend printed on the board setting the switch to 1010 SHOULD make it work at 133mhz. Only problem is when I try to do that it doesn't boot. So I can run my XP processor but only if I underclock it at 100Mhz... which rather defeats the point! SO...
PLEASE someone help! What am I doing wrong... and can someone PLEASE find a manual for the board and post it to a sie somewhere...
HERE IS THE MANUAL and quite likely the BIOS
for the TIME GA-7ZMMP
http://bartscontest.com/denovo/gnome/GA_7ZMMP.zip
I am still using this mobo - so if I can help out, please mail me via the addy enclosed.
Gnome
Gnome
