Help me identify this motherboard ...
monreal
My BIOS string is:
09/25/2001-i810(E)-w8362-6A69MTRAC-00
1st 5 digits (6A69M) indicate: 'Intel i810(E) chipset with Award BIOS' v6.00. However, I cannot find any info for the manufacturer, i.e. 6th & 7th digits (TR). TR is not listed in the Award Hardware Vendors list on this site.
How can I identify the manufacturer?
Actually I am looking for Win XP drivers for my motherboard. I already know the built-in display/sound card models. Would this info be enough to locate the correct drivers for display and sound? Or do I need to know the motherboard model as well ? Can anyone refer to me some good drivers sites plz ?
soupy
Absentee administrator
I think the manufacturer is Topstar.
http://www.topstar1.com/html/homepage.asp
XP should fully support the i810 chipset already, though.
NickS
BIOS Bodhisattva
TopStar certainly use TR, e.g.
TM-810E2/EL2
11/01/2003-i810-W83627F-6A69MTRCC-00
TM-810E2/EL2 REV2.0 (2003.11.01)
and even
09/25/2001-i810(E)-W8362-6A69MTRAC-00
TM-810TL RPX/TC VER:1.1 (2003.09.19)
That message TM-810TL RPX/TC etc should appear at the top left of the memory count screen under the Award logo.
