i need help turning off the onboard sound on an old computer through the Bios the coad is = 2A5IMG09
that is the Bios Coad and it is an "Award"
Help
Gigabyte GA-5SMM.
ESS Solo-1 PCI Sound chip.
There are no BIOS function to enable/disable integrated sound.
JP1 jumper select this function.
On-Board Sound Function Selection:
1-2 = Enabled
2-3 = Disabled
Jumper can be located between PCI and ISA slots.
1-2 = Enabled
2-3 = Disabled
