Identifying my Motherboard
Sue
Can someone please help me identify this board as I would like to find out the specs. The only markings on the board that I can see are:
PWA-ELISE-SWAP BD
PCB 316701200001-R01
ASSY.411701200001 R
The only other info I can get is after hitting F10 at start up which is:
Product Name: Compaq PC
Processor Type: Pentium 3
Processor Speed: 800/133Mhz
Memory Size: 128Meg
System Rom Date: 06.02.00
System Rom Family: 686S6
Any help would be appreciated.
Sue
NickS
BIOS Bodhisattva
Google search turns up an IBM test lab reference to Compaq Presario 7E13 'Elise'. Compaq support doesn't mention 7E13 specifically, and the Documentation they have on "7EL" is scant. Try looking at ftp://ftp.compaq.com/pub/supportinforma ... ev2_us.pdf.
Another Google search suggests that Presario 7EL includes Presario 7000T. Does any of these numbers ring a bell ?
Sue
Thanks for your reply NickS.
None of them numbers ring a bell as I know nothing about Compaq Computers. I bought the system from a computer fair. It has been built from different components in a standard case so I have no idea if the board came out of a Presario.
Presario 5900T, ELISE, PCB:316701200001-R01, ASSY: 411701200001-R__, bios ID 686S2, S/N 8024DCWZ3xxx
CPU_____JP6___JP8___JP7
Intel 66___O____O____S
Gobi 66___S____S____O
Gobi100___S____O____O
Gobi133___O____O____O
mult__JP2 1=1-2, 3=3-4, 5=5-6, 7=7-8
1.5___3
2.0___1,3,5,7
2.5___1,3,7
3.0___1,5,7
3.5___1,7
4.0___3,5,7
4.5___3,7
5.0___5,7
5.5___7
6.0___1,3,5
6.5___1,3
7.0___1,5
7.5___1
8.0___1,7
and it's used in the 7800 and 7900 series as well on some models...
Sue
Thanks for the info edwin. By any chance do you know where I can download a manual for it?
Sue
I'm trying to find one. Can you find a part number similar to 170390-102 on the board surface somewhere?
Sue
On one of the PCI Slots there is a sticker on it with the following details.
Replace with Compaq Spare
SPS-BD SYS W/1394;ELISE-2
Spare:207611-001 : Part No:187221-101
Sue
Found a picture, now to find out what system it was from.
Listed as being in the 7EL147 (Canada) model. The MSG for that one refers to
ftp://ftp.compaq.com/pub/supportinforma ... 7AP-EP.pdf
Which is pretty useless where it comes to the actual locations of the connectors etc. More than that, this is one of them dr**ded boards with an integrated front panel thingy. Unless you have the matching case it is not going to be easy to retrieve the connections...
Sue
Thank you for finding out for me which system my board came out of.
I am not sure what you mean by an intergrated front panel thingy as this board is in a standard ATX case.
Regards
Sue
The original Compaq case has got an LCD front panel thingy, you connect it with one connector block of which the pin designation is not yet known.
