I searched...
win bios
Amibios
Award bios
the web
Bios String...
WL81020A.15A.0004.P03.0004041700
Could some one help me locating this motherboard manual, please?
It is from a gateway computer, and the PC hangs at the win98 splash screen, so I can't run the tools to check the system out.
Just need to find the motherboard manual for now to see when I take it apart, if there is anything else I can add to it.
Thanks, ...........daljaxon
I'm looking for a Motherboard Manual
Gogle search on W81020A turns up:
1. Our Edwin's site which identifies it as Intel "Willow Springs 2" WL810E and links to Intels' OEM motherboard data
http://www.intel.com/design/motherbd/oem/index.htm
2. http://support.gateway.com/support/driv ... type=10079 for an up-todate (P06) BIOS
You can enter your system serial no. at Http://support.gateway.com for support for your system.
