Need help ID my motherboard please
LeeHamo
Mon Nov 20, 2006 11:09 pm
I nee the maker of my board so I can identify it in speedfan and find out which temp is temp 1 so i can hopefully stop this damn system overheating.
Cheers.
Specs below:
Award Modular bios v6.0pg
W6378MS V1.5 081601 14:51:57 (TIME COMPUTER SYSTEMS)
08/16/2001-8361-686B-6A6LMM4SC-00
I hope this is enough info for you.
Lee.
LeeHamo
Mon Nov 20, 2006 11:38 pm
I also just put some new thermal paste on cpu to try and stop it ovierheating and on the first boot after doing this it overheated and shut down quicker than it used to.
Any ideas?
Lee.
BIOS Guru
Tue Nov 21, 2006 12:50 pm
MSI MS-6378 (probably a Rev 1.x), seems to be OEM'ed for Time Computers but using MSI standard Bios
http://www.msi.com.tw/program/products/ ... php?UID=22
Latest Bios is 1.9, do not use 3.x Bios !
Make sure your CPU and cooler are properly seated and your cooler is not twisted by 180 degrees. Also use a very slim cover of thermal paste. Your correct CPU temp and probably your system temp should be shown in Bios. Adjust Speedfan settings accordingly.
