Manual 4-62-1021-001124-00101111-071595-SiS620-1SIS6200
Request help finding jumper settings or a motherboard manual.
l0lapx
Program: Unicore BIOS Wizard Version 3.23
BIOS Date: 05/19/99
BIOS ID: 62-1021-001124-00101111-071595-SiS620-1SIS6200
OEM Sign-On: UD6122n
Chipset: SiS 620 rev 2
Superio: NSC 351 rev 2 found at port 2Eh
OS: Microsoft Windows 98 SE Version: 4.10.2222 A
CPU Type: Intel Celeron
CPU Speed: 400 Mhz
CPU Max: 466 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 128 MB
Regards Jeana
Memory Maximum: 512 MB
Memory Slot 01: 128 MB
Memory Slot 02: 0 MB
ajzchips
El cheapo dude
001124 is TEKRAM: http://www.tekram.com/
Can't find any SiS board at Tekram that could match. Any inscriptions on the motherboard?
Could be Compaq OEM. What system is this in?
l0lapx
The MB is in a Compaq Presario 5346 Unit
Regards Jeana
Must be a replacement board then, the 5346 has an Intel i810 chipset, not SiS620. You are sure you have written down the exact bios string?
l0lapx
TU,
AJZCHIPS - the only inscription I could find was "CE31-A" between the PCI Slot and SiS620 chip.
EDWIN - What do you mean by "what system is this in"?
AJZCHIPS - I went to the link to COMPAQ and I am going round in circles
EDWIN - The following was picked up by BIOS AGENT program
BIOS Date: 05/19/99
Motherboard Manufacturer: Compaq
Motherboard Model: Compaq PC
CPU Speed: 400 Mhz
CPU Max: 466 Mhz
Thanks Again for your help, I am going crazy here.
Jeana
FIC CE31-A
Now there is something weird going on. The AMI ID code for FIC is 001121 not 001124
62-1021-001124-00101111-071595-SiS620-1SIS6200 so either the bios wizard goes haywire or someone at FIC or Compaq scr*wed up badly.
However, this doesn't matter for the manual/settings, which can be found here:
http://www.fic.com.tw/support/motherboa ... odel_id=52
l0lapx
The board is apparently made by a company called FIC (First International Computer) and the CE31-A might just be the model number of the board.
So I have listed the links I was given just in case it can help someone else. Many thanks Jeana
http://www.google.com.au/search?hl=en&i ... arch&meta=
AND
http://www.fic.com.tw/product/motherboa ... odel_id=52
AND
http://www.s87841630.onlinehome.us/mode ... E31-A.html
Thanks Again for all your help.
l0lapx
SORRY EDWIN,
I didn't get your message until after I posted my previous one.
Many thanks for all you guys have done.
Appreciate it muchly.
I can now get to work on this PC after I do my reading.
Have a great one or two or more
Jeana
no prob. happy tinkering.
l0lapx
:roll:
Thank you, I will.
Thanks again to all
Jeana
