![Shocked 8O](https://www.wimsbios.com/forum/images/smilies/icon_eek.gif)
BIOS DESPERATION HELP!!
I"m in a heck of a jam I tried to flash my bios on a asus a7n8x dlx I downloaded the bios , extracted the files to floppy rebooted hit alt+f2 to enter awardflash utilitythen entered the bin file into the flash utility all was going ok untill I tried to flash the stupid thing frooze up and is stuck on the screen that says danger do not restart or turn off what can I do? can I reboot and clear the cmos and be ok or will I kill my board I left it running and came over to friends house to look for help Thanks for anything that you may suggest ![Shocked 8O](https://www.wimsbios.com/forum/images/smilies/icon_eek.gif)
The only thing you can do is reset or power down. If it started to flash, you will most probably get BIOS ROM Checksum Error and BootBlock BIOS.
