I want to make an update to my bios but i don't find anything about it..i think that Wim's BIOS can help me..i made a report with eSupport Bios Agent :
Program: eSupport.com BIOS Agent Version 3.53
BIOS Date: 11/01/02
BIOS ID: 62-1101-001131-00101111-040201-VIA_P6-MS9138E
OEM Sign-On: MS9138E Release 11/01/2002
Chipset: VIA 82C3148 rev 0
Superio: ITE 8705/SiS 950 rev 2 found at port 2Eh
OS: WinXP SP2
CPU: Intel(R) Pentium(R) 4 Processor 1700 Mhz MAX: 3000 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 4096 MB
Memory Slot 01: 128 MB
Memory Slot 02: 128 MB
Memory Slot 03: 0 MB
Memory Slot 04: 0 MB
thanks in advance(sorry for my english) ...
I need some little help ...with my Bios
Matsonic MS9138E (surely has a Eurone/PCChips/ECS-brother, too)
latest bios from KURIAKI's archive (Matsonic support site is down atm):
http://kuriaki.myftp.org:8245/Archives/ ... 030522.zip
use amiflash or uniflash.
EDIT: http://www.hardwaresecrets.com/printpage/65/
MS9138E is M925 from PCChips :)
i have another problem... i put the amiflash exe on a bootable disket and the .rom file ...when i've typed in ms-dos to run amiflash(after the disket boot) it gave me a message that is missing a file..please help(sorry for my poor english)
Verification error = Flash failed
Data supposed to be in the Flashrom does not compare to the data in your file used to update. Maybe there's some kind of flash protection enabled, either per Bios or per Jumper.
Look at JP4 jumper.
Pins 1-2 position is the correct.
i've looked on the mainboard ..and i can't found it... can you tell me a position where can it be (sorry again for my english) thx in advance
Good news i found it...and it is on 1-2 position...the problem continues
I'm starting to wonder if it's not some Y2K6 self destruct mechanism...
I wanted to update the bios because of power issues, ie. would not shut down thru software nor hardware without holding down the power button for 4-5 seconds.
MY MAIN question is, how long should it take for the bootblock mode to recognize the AMIBOOT.ROM? I have now collected almost all the variants of bios for this board. It was identified by the ami-ID to be an ECS (EliteGroup M925). Unfortunately I did not know that the provided flash program would not automatically save or even prompt to save the original bios. doh.
Flash failed and now so is my sanity.
Other than the power issues the board was working fairly well for the time I had it running which was about a day.
Has anyone ever sucessfully recovered via the bootblock failsafe?
I put the floppy in formatted to 1.44, hold down ctl + home and turn on the box. It then continually acceses the floppy, ie. "access...beep...access...beep...etc. ad infinitum"
The jumpers are all correct.... Should I short the cmos DURING the flash?!?!? I took out the cmos battery the last time I cleared it and left it out now since I was having no luck otherwise.
I've also tried putting amiflash.com and dos4g.exe and F82741.exe on the disc as well but to no avail.
I also put in a query to the bios site but no word from them, yet. Maybe the holiday has kept them busy.
? h e l p ?
I'll put up the ami-id info page once I get it off the drive that I didn't back up, if that will help.
edit: Here's the amibid info for future referrence...
? h e l p ?
Code: Select all
BIOS String info:
An AMIBIOS ID String Was Detected:
62-0703-001131-00101111-040201-VIA_P6
| | | Chipset/BIOS Info
| | BIOS Build Date
| Manufacturer ID
BIOS ROM Information
AMIBIOS ROM Size: 256 KB
BIOS Build Date: Apr 02 2001
Motherboard Manufacturer Code Detected: 1131 - ELITGROUP
Please Consults ELITGROUP for support
AMIBIOS Build Tag: M925
SMBIOS info:
Manufacturer : ECS
Product Name : M925
Version : 1.0
Serial Number: 00000000
there are several reasons for a verification error.
1. the bios chip is (partly) damaged
2. the bios chip is protected against writing (either bios option or hardware jumper)
3. the bios chip is a replacement chip and not designed to be flashed at all
4. the bios chip is a replacement chip and not designed to be flashed in THIS mainboard (e.g. requires a different programming voltage)
5. the bios chip is not supported by the flasher you are using or by any flasher at all
with amitboot you only need AMIBOOT.ROM on your floppy..you can release CTRL+HOME after it accesses the floppy btw.
check this site for further instructions.
power off after 4 seconds is the standard setting for any atx mainboard. there is nothing wrong with this. you can change this behaviour in the bios.I wanted to update the bios because of power issues, ie. would not shut down thru software nor hardware without holding down the power button for 4-5 seconds.
Thanks for the response cp,
The power issue was not that it took 4 seconds on the button but that the power button method was the only way the motherboard would shutdown or reboot, ie. no software shutdown at all, not even ctl, alt, del. Even the reset button had issues.
I think I will just induct this board into the Hall of Doody since I could just get a much better board on ebay for the price of a new bios chip. Or just sell the P4 1.7 and fan that was supposed to live there. Any takers?
