cpu speed incorect setting when cold boot is done
hi dont no if this should b here but i need help my problem is when i power on my pc it boots up then the post screen comes on shows correct cpu speed cyrex 3 533mhz but a warning message says cpu setting incorect push f1 to set . i have done this and saved it to the bios in the set up then it works fine i reset it it works fine but when i switch it of proply and then back on it says same my mb is a pc133 m758lmr with a ami bios id is{ 62-1221-009999-00101111-071595-000000 m758lmre}it all works fine just a bit of a pain when i have to do that all the time when i turn pc off the cpu has a 133 bus to i also put memory and a graf card in it would that b the problem? can any 1 help
You may want to try upgrading your BIOS: ftp://ftp.pcchips.com.tw
It is a good reply. But which Bios shoud we use?
For sis630 or sis630e?
Pc-chips made this motherboard with both chips. And Bios after
some period of time was switched from M758lmr to M758lmre.
What will happend if I install wrong Bios?
I'm almost 100% convinced that the SiS630e BIOS release is backward-compatible with the SiS630 version of the board. They must have separated the 630 and the 630e folders because the 630 BIOS isn't forward-compatible with the 630e versions.
So I can try to use Relesae bios
Filename :010510s.rom
Checksum :FD26h
Release date :2001/05/10
ECN :J450162
It looks to be the last one. I am afraid to do that because there is
no PC service around. And in case of unsuccessful upgrade I will need to
repaire everything by myself. Or order the new motherbord
Anyway thank you for support.
Checksum :FD26h
ECN :J450162
On www.amptron.com there is no new one. And on www.pcchips.com.tw
bios archives does not containe RELEASE.TXT file. So it is hard to
understand for which motherboard is this bios. Also their ftp looks like
madhouse now.
madhouse now.
