Hello.
I upgraded my cpu but when I boot up the computer it gives me 1 short + 1 long beep repeating on a black screen. At first I thought this was an hardware issue - but after some research and asking around on forums it seems to be an BIOS-issue.
Apparently my mobo and chipset can handle the new cpu, but the BIOS are so poorly constructed that it won't allow it.
I was hoping some BIOS-genious knew a workaround... Here are all the necessary info (I hope):
My computer: http://www.manualslib.com/manual/435619 ... e=2#manual & http://www8.hp.com/h20195/v2/GetPDF.aspx/c04288430.pdf
CPU upgrade: from *E5500, 2-MB cache, 2.80 GHz* to *Q8400, 4-MB cache, 2.66 GHz*
Beep code: Memory issue.
Memory: 8gb (1x 4gb + 2x 2gb) PC3-10600 DDR3
wmic baseboard get: Manufacturer: Pegatron Corporation / Product: 2A94 / Version: 1.03
BIOS version: American Megatrends Inc. 6.09, 2012-01-16
SMBIOS version: 2.5
OS: Windows 7, 64-bit.
Tried: Running it with no memory sticks, running it with 1 stick (and switching sticks), reinstall BIOS, downgrade BIOS (since the version I already had was the latest), upgrade BIOS from the downgrade.
Additional: New thermal paste between changes and all that. The fan doesn't seem to run any faster than usual when I try to boot with the new processor. And when I boot up with the old cpu back everything runs fine.
Hopefully someone can help, thanks in advance.
HP Pro 3120 MT CPU upgrade gets beeping.
Eureka3 motherboard
http://www.ctechinfo.net/motherboards/p ... ureka3.php
Supports only 2GB modules so you need to change that 4GB with 2x 2GB. It seems that for the x8*** processors you need v6.09 of the bios
ftp://ftp.hp.com/pub/softpaq/sp56501-57000/sp56794.html
ftp://ftp.hp.com/pub/softpaq/sp56501-57000/sp56794.exe
